Solid Union Not Working
Could someone please explain why solid union does not work in my script. I’ve tested it with a different set of breps and it worked fine. I even tried join brep but no luck.
Solid Union (internalised).gh (47.3 KB)
TIA
H
@hayden you did not internalise the referenced geometry in the file you posted.
-Kevin
Apologies. Done.
H
instead of digging into why Solid Union doesn’t work (it could be many causes, non-manifold edges intersection, tolerance, drawing scale… I know it’s not very reliable) I would draw things in such a way they can be extruded:
instead of this:
this:
Solid Union_Re.gh (34.6 KB)
[for some reason the Rhino file was also there 10 minutes ago… geometries are internalized)
Thanks @inno
