Solid Text to PDF in Shapediver
Does anyone have a reliable way of creating solid black text in a shapediver generated PDF? I have tried the shapediver text component but the rectangle input is difficult to work with and often results in rotated text. I have also tried using the text curves component with a solid fill but the resulting text is solid black with no “holes”.
Thanks!
@davidchristiankoch Are you using the Squid plugin? If so, that should work correctly. Could you upload a minimum GH example of the issue you are experiencing?
An alternative that is now supported by ShapeDiver is the PDF + plugin: https://www.food4rhino.com/en/app/pdf
