Solid subtraction - control points
Hello!
I wonder if it is possible to manipulate (not only move) and transform the object subtracted from the wall, fe. with a command transform 1D. I am not able to achieve any change…(see picture below)
Petr
Hi Petr, that’s not possible. You can only move the solid subtracted using its control point after the subtraction. You will need to extract the solid (vaExtractSolids) to edit it, and subtract it again from the wall.
Hi Francesc,
okey thanks for suggestion :slight_smile:
