Can anyone assist.
I’d simply like to place the solid forms on top of the plan. Not sure what is going on. I’ve tried multiple materials all display settings. Checked the textures tab, everything looks normal. Also tried badsrf.
Thank you!!
Thank you!!
Hi Limor -
Could you please run the Rhino SystemInfo
command and copy-paste the result here?
Apart from that, a simple 3dm file in addition to a picture is most often required when we need to debug something.
Rhino 7 SR28 2023-2-27 (Rhino 7, 7.28.23058.03001, Git hash:master @ 4ffc5d7156fbccf2a5d9fcc80e522b3851bc7f6c)
License type: Educational, build 2023-02-27
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display and OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 12-20-2022 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.3889
- Laptop lid is possibly closed
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 31.0.101.3889
Driver Date: 12-20-2022
Driver Version: 31.0.101.3889
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.28.23058.3001
C:\Users\Limor Joel\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\MeshCommands.rhp “MeshCommands” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.28.23058.3001
for forum.3dm (801.4 KB)
Thanks so much
Also if possible, I recall perhaps on rhino 6 you could revert to previous versions of a file, is that option still available on rhino 7- It looks like you can only revert to last saved.
Thank you!
use ClearDrawOrder
Thank you so much, worked a charm!
just to be sure you also know what happened here, somebody if not you used commands like BringForward (in steps) or BringToFront (places the objects completely in front), then these objects (unfortunately only hatches and curves) will always be seen over any other geometry which can be useful for several instances. you can go the other directions with SendBackward or SendToBack and ClearDrawOrder brings all back to its initial state.
