And I don’t know how to fix it, since the antennas are both close solid objects and I BooleanUnion successfully with the body part. So the whole object has no naked edges and it’s a valid polysurface. (closed solid polysurface with 5064 surfaces)
Hello - yes, I just mean, with such a simple thing, might as well build it cleanly in Rhino. Your BooleanUnioned object should print OK, and here’s a simplified one - Antenna_Simple.3dm (1.4 MB)
Hello - I made Circle> 3Points, snapping to the ends of the faces around the existing bars, then used the center of the circle as the start of a vertical line, then Pipe > Caps=Round on the line. All the parts are in the file I posted.
