Solid Hatch not display before I drag the hatch
Hey,
I tried using some code to add solid fill patterns to closed curves in bulk, but after running the code, I couldn’t see any fill patterns.
When I selected all the shapes in the viewport, the command line showed that the fill patterns were already selected, which means the fill patterns were successfully created.
When I dragged or stretched the fill patterns using the control axis, they reappeared. What’s going on here?
Solid Hatch Problern
Solid Hatch not display.3dm (240.8 KB)
Hi -
When I open the file and run SelBadObjects, the hatch object is selected.
You might want to provide the code that you used to create this object.
Hi Wim Dekeyser, The code to create solid hatch is below
                          foreach(Curve crv in Crvs)
                              if (crv.IsClosed)
                                  if(crv.ClosedCurveOrientation(Plane.WorldXY) == CurveOrientation.Clockwise)
                                      crv.Reverse();
                                  Hatch[] hatchs = Hatch.Create(crv, (int)HatchIndex, RhinoMath.ToRadians(HatchRotation), HatchScale, doc.ModelAbsoluteTolerance);
                                  foreach (Hatch hatch in hatchs)
                                      if(hatch != null)
                                          hatch.Plane = Plane.WorldXY;
                                          doc.Objects.AddHatch(hatch, obj_attr);
Hi @1056960357,
Seems like you need to Redraw when your finished.
doc.Views.Redraw();
– Dale
Hi Dale @dale
I don’t think so.the problem file attach below the post
