Solid extrude surface straight to solid separate part
Hi!
Solid extrude surface straight acts weird.
I have bounding box and want to extrude new solid block from the bounding box surface.
I had option “solid” on. So this means I can’t make new solid block from that surface?
This is “solid” off,
Now it is separate “block”. But then I have to cap it.
My opinion is that there should be options “solid” and also “join”.
“Solid on/off” option means it makes it solid or not
“Join on/off” option makes it to join to the original surface or not.
Maybe there is some trick I don’t know :slight_smile:
I use Rhino 7.
Thanks
Hi @Wagner
If you set DeleteInput=No the new volume will be separate from the original, if that’s what you mean :slight_smile:
HTH, Jakob
Hi Jakob!
That’s it, thanks :slight_smile:
Not a bad day, learned something new :slight_smile:
