"Solid Difference" using imported block
I am wondering what the best process to do a “Solid Difference” operation using an imported block. The error “1. Data conversion failed from Block to Brep” appears when attempting the operation. Would I have to bake it, then reference it, and then do the “solid difference”?
Thanks in advance
Hi Brendan -
Unless you find a Grasshopper plug-in that can deal with blocks, yes, that’s what you’ll have to do.
Ok, Thanks
