Hi All
I also meet a question about “Solid Difference”…
If one one solid(A) is inside another solid(B), “Solid Difference” doesn’t work.
Solid Difference.gh (531 Bytes)
Any solutions?
Thanks in advance.
Hi All
Any solutions?
Thanks in advance.
Thanks.
There seems to be no solution.
It may be possible to write a python module to do this. RhinoCommon contains the MergeBreps method which will create the non-manifold brep. You’d have to track down, or ask the developers, about the “create regions” part of the process though - I haven’t sussed that bit out.
Ah… I think it’s impossible. I tried this…
BrepOnion.gh (9.9 KB)
which makes half a big cube, boolean diff the smaller inner cube, mirror result, Union the results, merge faces.
The Union cannot create a Brep with a void in the middle.
There’s an explanation for this but I can’t remember. Perhaps one of the McNeel guys can explain?
Can you work in Meshes instead?
