Hi there, home you doing well, i want to cut a rectangle surface with a set of scaled surfaces but the solid diference don’t work quite good.
1-2-1.gh (19.8 KB)
could someone help me solve this
1-2-1.gh (19.8 KB)
ooh sorry
1-2-1.gh (23.9 KB)
That happens because your data branches doesn’t not match in the cluster , you should simplify
ooh… lemme try that too
This should work for you : (Surface split runs a little faster here than using Solid difference )
It worked just fine , thx i really appreciated it
I have to thank you too Jessesn for your concern
Thank you for you help
