Softening edges
Hi All,
I would like to softening edges of some solid in grasshopper. I can’t find the command, either in RhynoPython syntax. There is some way to do this or it is a limitation?
Thanks,
regards,
Roy
Please be a bit specific about what soften means and what solid means. Is solid a mesh, a surface, a brep. Do you mean to smooth a mesh or to fillet a brep edge, or something else. Images and files also help.
Hi Michael,
thank you very much for your message.
That’s’ my problem.
I’m looking for a workaround to create a Visualarq style with the option to softening edges the objects. This option is not yet implemented inside Visualarq but:
after have created the Va object inside Rhino, this object for Rhino is a block. If I edit the block in place and I give to its subobjects the softening edge option, then I close the block, all it works perfectly! I have my Visualrq object with softening edges.
Now the issue: I don’t want to do all this work for all the objects of the model, so I need to create, if possible, a Visualarq style with the softening edges option or save the new object I’ve created as a new Va style, or, that’s why my question here, try to create a new Va style from grasshopper that will include the softening edges option. So I’m asking if there is, maybe with python or other, to have the softening edges option inside grasshopper (for a brep).
I know that probably this workaround it doesn’t exist and I need to wait for Asuni will upgrade the style creation with this option, but never say never…
Thanks,
R.
Hi Roy
I had a similar problem to yours and found this solution:
Softening edges.gh (43.9 KB)
I used this code from the Rhino Developer side:
Link to Rhino Developer
Not sure if this helps You, it only works for Meshes.
Greetings,
Josh
Hey @locherschmuck. Thanks for posting this, however I am getting an error with your c# script and hoping you can help troubleshoot? I’m using Rhino 5 (64)
  1. Error (CS1061): ‘Rhino.Geometry.Mesh’ does not contain a definition for ‘WithEdgeSoftening’ and no extension method ‘WithEdgeSoftening’ accepting a first argument of type ‘Rhino.Geometry.Mesh’ could be found (are you missing a using directive or an assembly reference?) (line 70)
