Hi, we’ve added a topological distance option to SoftTransform in the WIP. It’s called Along Surface. Please take a look and let us know what you think.
Hi all,
In the Rhino 9 WIP we’ve enhanced SoftTransform .
SoftTransform makes it easy to adjust large numbers of control points by applying a falloff influence to the transformation for surrounding points.
To try it:
Run the DragSettings command or right-click where your panels are docked and bring up the Drag Settings panel. This panel also provides easy access to your drag mode and drag strength.
Then, check the enabled box underneath the Soft Transform heading.
When sub objects …
