My rhinocommon plugin needs to soft edit one surface on a closed polysurface (made up of trimmed surfaces). The user will specify the location, u and v distances, and height to be soft edited.
If I were doing this in Rhino manually, I would explode the polysurface, soft edit the desired surface with fixedges on, and then join the trimmed surfaces back together, using joinedge to join anything not watertight.
In Rhinocommon, I don’t think I explode the brep, but rather get a list of trimmed surfaces, but I don’t see this option. Is there a way to get this? My plan then is to script the soft edit on the appropriate trimmed surface, then join the trimmed surfaces back together into a brep and use brep.joinnakededges to get it watertight.
The purpose of all this is to allow a user to add what is known as a metpad to a foot orthosis, which adds pressure (usually just behind) the metatarsal region of the foot. So basically, I’m just trying to bulge the volume of the orthosis in that region with a bit of user control. If you have any better suggestions on how to do this, I’d like to hear.
To “explode” a Brep in RhinoCommon, you would do something like:
Brep toExplode; //defined elsewhere
Brep[] exploded = toExplode.Faces.Select(bf => bf.DuplicateFace(false)).ToArray();
// soft edit here - I have no idea how to do this, you mention scripting it?
double joinTolerance = doc.ModelAbsoluteTolerance;
Brep joined = Brep.JoinBreps(exploded, joinTolerance);
while (!joined.IsSolid)
joinTolerance *= 10;
joined.JoinNakedEdges(joinTolerance);
I think in vb.net and so tried a converter with your code but it had trouble. Select doesn’t seen to be a member of Faces, what am I missing?:
Also, are you sure faces maintain trims? When I add all of the faces of a brep to a document, I get the untrimmed surfaces:
For Each BrepFace In toExplode.Faces
doc.Objects.AddBrep(BrepFace.ToBrep)
Next
I just realized a problem with my approach though; fixedges fixes the surface edges, not the trimmed edges, right?
So if I soft edit too close to the edge, then I won’t be able to rejoin… Looks like I will have to retrim the surfaces to each other.
A soft edit that worked on polysurfaces would be great. Anyone request this yet?
