hi @lars, this is exciting! I’m glad you guys are tackling this one.
in case you haven’t seen it I talked about what’s needed here:
What I had listed at the time was:
Views
Material assignments
Layer visibility
Object visibility
Curve Shutlining on/off (important for design variations)
Named position
Active clipping planes/Section views
Active foreground/background images
Grasshopper configuration states…I would also add:
displaymode
and more importantly two challenges about displaymode:- _SetObjectDisplayMode state of objects
- overrides of visibility in the display panel (like curves of/off, show wires, transparency, etc)
In terms of management I want to be able to reorder them manually and duplicate them. If I rename ‘snapshot 01’ to ‘coolview1’ shouldn’t the named views/named position/layer state generated at saving ‘snapshot 01’ be also renamed to ‘coolview1’ ?
Also a playback button to go from previews to next would be nice. Especially for presentations. even an autoplay with a timer. Can you make smooth transitions between them?
Can you load a snapshot in Layout view and maintain it persistent in a layout viewport.
Last thing: can you export snapshots as screenshots or files (like Step/STLs)
OK, I better stop this should be enough work for a few days
G
