Objects position doesn’t change from one snapshot to the next despite being in different positions when the snapshots are created. Just to make sure there wasn’t something wrong with my process, I replicated it exactly on Rhino 8 and it worked as expected. It appears to be broken in WIP. System information attached. Thanks!
I’ve attached basically identical v8 and v9 files with two snapshots created using exactly the same process, at least as far as I can tell. I made a square, clicked the button to save a snapshot, chose the options in the attached screenshot, and clicked apply. I then moved the square 6" and did that same process again for a new snapshot. In v9, when toggling between the two there is no movement. Conversely, in v8, using the same steps, the square moves as expected.
