Snapping to VA Walls changes an elevation of objects
Hello!
I’m looking for a reason, why objects/elements/walls snapped to the VA Walls, will sometimes change their elevation, because it is pretty unwanted behavior.
Hi @Kida you are snapping to the sectioned boundary of the wall, which is located at the level Cut plane elevation. In order to avoid surprises like that, just enable the Project Osnap when working in plan view from the top viewport.
Looks like it solves it
Thank you~!
