Is there a direct way to do this? Ie, find the closest point on surface to a given point? I used Project to first project a curve, then snap my points to those, but I’m wondering if there’s a simpler way?
thanks,
david
thanks,
david
Hi David - I don’t have Mac running here but OnSrf and PersistentOnSrf osnaps should help if those are implemented.
You might also want to look at the ClosestPt command. --Mitch
Don’t seem to be in a simple test here.
Never used them before, put was intrigued .
They’re in the “one-shot” section, and only when a command is active… --Mitch
Thanks
