Snap drag tolerance when using a larger mouse size
I’ve run into some issues with snappy dragging. Basically, my mouse is set to a size 4. On my end it looks like I’m clicking right on the corner, but when I screen recorded the issue it reset the mouse to a default size, and showed that I was in fact clicking too far off to enable the snappy drag. Any ideas for how to resolve this?
Best,
Paul
Hi Paul - there are two things that control this - testDragOSnapDelay (default 250 ms, I prefer 150) and snap radius in OPtions > Modeling Aids
default is 15 - I’d try doubling that and see if it gets you more snapping.
That worked perfectly. Thanks Pascal!
