I am just curious why Snap and Selection Filter become colored buttons?
What wrong with checkboxes? Currently they look clean and neat.
Pusht this to become the new standard layout, I love it!
Like @Gijs mentioned, I don’t think we’re there yet for the dark mode color of selection filters.
However to expand on the “why” more. The problem that v7 and v8 started having was OSnap and Selection Filters being mistaken too easily because they were in the same container with similar text and similar controls. Our plan is to try to help everyone visually distinguish these easier, but there is work to do still.
Interesting. To me, checkboxes are super messy, and these buttons (and their current layout) are much more readable and easier to hit (visually larger and more defined target). And they take up less space, so they’re a great UX improvement for V9! ![]()
I just wish I could customize their colors.
And maybe put them in two columns rather than two tabs? (The tab is an extra click.)
Hi Robert -
Those are two different panels that are in the same container. You can easily put each in a different container.
It would be nice though if those two containers could sit side by side where a single container is on top of it. Splitting this way is currently not possible.
Good point, makes sense!
But when im looking for the rest of interface it looks more consistent with checkboxes because they are all over the interface, so for me it is more minimalistic and clean interface, so may be it should be kept as option?
For instance, it looks in harmony when the command menu and filters are in the same sidebar:
I have to say, these are far too small and messy for me to be able to understand any of the icons. I’d rather just go back to having just the text in the buttons because since I don’t understand the icons they’re just distracting me from the text which I am able to read.
Also, since I’m re-drawing basically all icons anyway, am I going to be able to replace these? Or is this going to be the new clown panel for me (a panel which has improved, but where I still can’t re-draw the icons for)?
@eobet all flavors are now available. For the time being through test command TestOsnapToggles.
Panel icons and these icons cannot be customized.
TestOsnapToggles, or something with the same functionality, needs to be a regular command/feature in V9 before it is released. The modes with icons are unacceptable to me.
A switch from a command to the Options panel may be appropriate because for most users these paramters will probably be “set once and forget”.
we agree, that is the plan.
