Smoothed Contour Mesh from Grid Analyzed Mesh
I am really grateful to you, you gave me a beautiful gift.
Greetings
Dear Riccardo,
sorry if I have to disturb you again.
I have the same problem (referred in the previous comments) to re-construct the mesh, to give the colours to each faces. The value range for the iso´s script should be correct.
Mesh Spray is quite useful in this situation.
Instead of disassembling the meshes in a big lists of vertexes and faces, and reassembling a new mesh with a constant color for each vertex… Spray will just apply a color to the whole mesh (because we use a single spray point, so no interpolation happens)
Two notes:
1- If you are interested in the mesh alone, you can directly bake Custom Preview.
2- If you use 9 isos, you’ll have 8 meshes. So your colors need to be one less than the number of isos.
I’ve used Shortest List for this reason and also to help the tree structure to align. You’ll need to use it even if color amount is correct at start.
