SMesh fails on extrusion
My goal is to turn each face of the extrusion into a mesh face, but that fails horribly:
2024-03-07_SMesh.gh (13.2 KB)
What am I missing?
(I can use Mesh, but then I that creates 16 mesh faces, which is unnecessary for this simple geometry.)
Hi Felix -
You could explode the input curve into its composing segments:
Thank you, but why do I need to do that?
That also means, I’d have to weld the faces at the end to get a single mesh as intended (and welds are giving me a headache).
Hi Felix -
This is more fall-out from the change in Rhino 8 where Grasshopper in general is now aware of extrusion objects, but not all existing components have been updated to correctly deal with those.
RH-80861 Grasshopper: Extrusion object to mesh
Thank you for the explanation, and thanks for the link to the bug report!
You can use the combine and clean component from Kangaroo to union the four meshes.
Thanks for pointing that out! There are some nice utilities in Kangaroo2.
