- Create a box (make sure part of it goes lower than the CPlane you plan to draw on)
- Create a horizontal clipping plane and set it to affect only that box
- Make sure the clipping plane is under the Cplane you draw on
- When you try to draw from Top View smart tracking does not work
- Also, if you try to draw a polyline, spline or polygon only the points appear until you finish drawing
Using Clipping Planes is really important when you work on top of point clouds, so you need to only see slices of the cloud, but the rest of the geometry is visible.
SysInfo.txt (2.7 KB)
