Small rhino problem!
Hi!
I hope to find here some help for my rhinoceros install.well the problem is strange,and its the first one i have with the program?!maybe its my fault .After the sr8 upgrade,and when i deleted some folder in my second partition of the main disc,its started and no matter what i do i cant stop this behavior.The program still works best,i save import etc…and when i close rhino it shows me a window with warning?–Error saving RUI file?
So i"m confused ,this is not a big problem,but a bit picky…After every rhinoceros file closing i must comfirm 3times to the warning?Tryed new install -everyth fine,and again after sr8 this started again??So could someone kindly help me?Big Thanks!
@Johnm, can you take a look at this?
Thanks Pascal for the reply!Im just reading all comments but is there a solution for that?
Well i find a quick solution for the moment,not a serious one but…in the properties window of the shortcut i selected run everytime as admin and in this situation theres no more problem with warnings??dont know why??heh !It works!
This problem should be fixed in the next release candidate. The problem is related to saving a RUN file associated with a plug in from a folder in program files when Rhino is shutting down. If you open Rhino and run the Toolbars command you can right click one the file and Saves to a writable folder.
