Small glitch in Rhino 8 and the Rhino 9 Beta
Recently, I had to do a lot of “Project To CPlane” commands.
Delete input: No, Yes
Yes, please!
Next time, the same question.
Yes, please delete them.
Shouldn’t Rhino remember the last answer to the command?
Out of curiosity, I tested it on the beta as well.
Same problem.
Some commands are “sticky” which means settings are remembered between uses.
Some commands are non-sticky.
Some commands, such asAutoAlignCplane can be set to be sticky or non-sticky.
It’s not obvious why some are and some are not sticky.
Because ProjectToCplane has always been non-sticky I strongly doubt that it will be changed.
It escapes me what the logic is behind making some commands “sticky and some non-sticky”.
You can make a short macro:
_ProjectToCPlane _Pause No
_Pause will wait for you to complete the selection step, once you confirm, it applies the “No” option and keep the original un-projected geometry.
You can replace it with Yes …
Thank you, Riccardo.
I’ll try that later tonight.
