Small buglet: text not selecting in rendered mode
Here’s an odd one.
Version 5 SR9 64-bit
(5.9.40520.20245, 20/05/2014)
text-select.3dm (295.5 KB) Rendered.ini (10.4 KB)
In the attached file, text becomes unselectable while in rendered viewport. Rendered.ini attached as well for reference, in case I have some weird settings.
If you change the display properties so that annotations are visible then the text becomes selectable.
I discovered this the hard way after sending out a giant print job with no text labels on all the panels (uuuurgh!)
Cheers, Steve
Hi Steve- got it, thanks.
http://mcneel.myjetbrains.com/youtrack/issue/RH-27431
(not visible to the public, yet.)
Fixed in V6…
