My file is running slowly particularly whenever I try to copy anything - even 2D Lines. I’ve tried purging, but it didn’t seem to help. Oddly when I copy something the command lines runs through saying “File does not exist…texture”, when I have purged textures, and am not even trying to copy any.Anyone know how to get rid of this info to make things run better?
can you identify where that texture is supposed to be? check your materials and see if any of them are missing a bitmap. If so, simply remap it.
if not, a trick i’ve used is to export out as step and then open a completely new file, then import the step data in… this will “wash” that data and remove anything attached to it.
