Slow Picture in Rh7
Hi Guys.
I use the picture tool a lot.
I saved and attached the same file (cheap 3d stuff + 145kb pic) in Rh6 and Rh7. While it works well in Rh6 it is incredible slow in Rh7. This is a really basic sample. Normally I have big files with lots of stuff and pics as I also make presentations in Rhino.
Any specific reason for that?
Can I change properties to speed up things in shaded view?
I am working on the latest versions of Rhino.
slow pic Rh6.3dm (345.5 KB) slow pic.3dm (345.5 KB)
Hello - by slow, you mean, I take it, that if you open this file that you posted, view navigation is slow, or?
Seems fine here so far.
Can you please run the SystemInfo command in Rhino and copy/paste the results here?
Hi Pascal
Right. While in Rh6 I can easilly import 20 pics, cut and transform them, it seams that naviagtion with my 3D connection Space Mousemouse gets slow and stuck in Rh7.
Here the info on my laptop. I am also working on a Dell Precision desktop with 64BG RAM with the same issue (I cannot send the data as I am not in the office these days). So Ram should not be the problem.
Rhino 6 SR34 2021-2-3 (Rhino 6, 6.34.21034.07001, Git hash:master @ 2fec8130f097ca52a8bc9f334c3ed4a5921c5e30)
License type: Commercial, Build 2021-02-03
License details: Stand-Alone
Windows 10.0.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: MONHAML4343
Primary display: Intel® HD Graphics P530 (Intel) Memory: 1GB, Driver date: 3-9-2017 (M-D-Y).
Primary OpenGL: NVIDIA Quadro M1200 (NVidia) Memory: 4GB, Driver date: 9-19-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 431.94
> Integrated acclerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-19-2019
Driver Version: 26.21.14.3194
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.34.21034.7001
C:\Users\hh-alt\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\Fologram for Rhino (468a328b-20d9-494b-b9e1-cbe9f827d3a2)\2018.10.1.0\FologramForRhino.rhp “Fologram for Rhino” 2018.10.1.0
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.34.21034.7001
C:\Users\hh-alt\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.12.17.906\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.34.21034.7001
Rhino 7 SR3 2021-2-8 (Rhino 7, 7.3.21039.11201, Git hash:master @ 7bcc02a54515376cb2bd3d05f62d9473ab4bc38c)
License type: Kommerziell, Build 2021-02-08
License details: Cloud Zoo
Windows 10.0.15063 SR0.0 or greater (Physical RAM: 16Gb)
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.3.21039.11201
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.3.21039.11201
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.3.21039.11201
C:\Users\hh-alt\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.12.17.906\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.3.21039.11201
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.3.21039.11201
Hello- it is probably worth updating both video drivers from the Intel and NVidia websites to the latest available; if that does not sort it out, just shot in the dark but you might try disabling this plug-in:
in Options > PlugIns page, and then restarting Rhino to see if that has any effect.
