Slow DWG Export
I have a file consisting of closed solid object blocks (no mesh, no texture no annotation etc.). Exporting this file as a DWG takes about 6 minutes. When I export each block instance separately, it takes about 1 minute in total. What is the reason for this? Is this a known limitation?
Hi hesro,
Please run SystemInfo in your rhino command line. An export of the file you send us took about 2 seconds.
Thanks
Hi Japhy,
whaattt :exploding_head: :exploding_head:
I asked Claude to repeat the export process and prepare a report. I sent you a link to this report via DM. I can see that Windows window ghosting plays a major role.
Hi hesro,
Thanks for the report, that helped a lot. With your exact command and the 2018 Solids scheme the export takes 109 s here as well, against about 7 s with the Default scheme, so writing solids is the bulk of the time and the ghosting you found makes it worse on top. That is likely also why the blocks one at a time add up to less, each export finishes before Windows marks Rhino as Not Responding. i’ve filed RH-99490 for the solids export speed. Until then, if the receiving end doesn’t need solids use a non-solids scheme, otherwise keep another app in front while it exports.
Hi Japy, thank you for your interest.
We would also be very pleased if there were improvements in import times in the opposite scenario.
I hope we’ll see improvements in version 9.0.
Apart from that, I’d like to bring up a different issue. If you’ve noticed, the 3DM file size is 100 MB, while the DWG file size is 25 MB. Yes, they use different geometry engines, but is it normal for there to be such a big difference between them?
There are a lot of factors that go into standing file size. Render meshes, if the file has been opened (if i recall dwg files are smaller until opened and saved), the tolerances have an affect here was well, how the precise the geometry is being calculated in their respective kernals, materials in files,… the list goes on.
Audit3dmFile in Rhino 9 has a great breakdown of what is contributing the the filesize.
Yes, it’s very useful.
However, as you can see, my file only contains nested blocks made up of solids. Nothing fancy. These are exported to the DWG file exactly as they are. The difference in file size makes me feel like something’s off.
I opened a thread about this before, but I don’t remember if I shared the file with you. However, I can prepare similar examples for you.
RH-99490 is fixed in Rhino 9 Service Release 1
