Funny slider behavior. I move the multiply node closer to the line SDL node and the slider takes on the name of the L parameter instead of the B it is plugged into:
I believe this is the intended behaviour - the slider’s “implied nickname” is taken from the closest parameter it is connected with.
You can always manually set a nickname via the right-click menu.
It has been that way for years.
Ahhh I’m a genius. You’re right - thanks friends.
