when I try to slide multiple edges in subd they move at different/ opposite angles what can be the reason? their sliding directions are pointing towards one another. it started happening after I applied bevel edges
Post an image or a file if possible it’s easier for everyone to understand the issue at hand.
Best is always to also post a file.
Sample_FIle.3dm (96.6 KB)
Here is the file
Please use RemoveSymmetry to remove the symmetrical feature from this subd object and then try again.
Sample2.3dm (128.5 KB)it is still happening even without the reflect/ symmetry axis
This looks like a bug to me. I’ve filed it as https://mcneel.myjetbrains.com/youtrack/issue/RH-90607
In the meantime, the only way to fix it that I found with your model is to select all the horizontal edgeloops > DupEdge > and SubDLoft with those curves to make a new SubD. However, this isn’t always a fix if you skip edgeloops. I don’t think Bevel is even required to make it happen too.
Sample2_bj.3dm (144.6 KB)
