Slice Pointcloud by Plane
I have been segmenting pointclouds using ;
Command: _Pointcloud
Select points ( Add Remove UsePointColors=Yes ): _Select
Select points ( Add Remove UsePointColors=Yes ): points
Select points ( Add Remove UsePointColors=Yes ): _Remove
Select point cloud ( Output=PointCloud )
Select points to remove ( Output=PointCloud ): _lasso
Is there a way of using a Plane to select points, to create a thin slice of pointcloud, instead of Lasso ?
Being able to set a selection “thickness” from the plane would also be a huge bonus.
Regards
Mike.
Hi Mike, is the goal to extract the points to a new point cloud ‘slice’?
Hi Pascal,
Yes.
Hi Mike - see how this works for you -
PointCloudSlicer.py (2.4 KB)
@Mike_A This one has a different workflow - allows preselection and offers more ways to specify the plane: PointCloudSlicer_2.py (3.7 KB)
@Mike_A - updated to preserve colors and normals, if any.
To use the Python script use RunPythonScript, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
The ‘SeekDepth’ option sets how far from the plane to look for points… so plane ‘thickness’ is twice this - not sure how best to present that.
Hi Pascal,
That works, but the pointcloud loses all of its colour (RGB) values (turns black).
Mike
Yeah, next step… I was trying to get out of work.
@Mike_A - is this better? I do not have any colored clouds just handy…
You can select thin slice of points with SelBox command.
Thanks Andrew,
But a Plane would be the best option. This way I can split the pointcloud from an existing 3D model.
Regards,
Mike.
Hi Mike - I think the version a couple of posts up will keep color - can you verify?
Hi Pascal,
Thank you, it now works with colour.
Regards,
Mike.
