"Skylight shadow resolution scale dynamic" settings do not work
I’m experiencing an issue where the shadows look too grainy during rotation for my liking. I tried adjusting the ‘SkylightShadowResolutionScaleDynamic’ to 1 within the advanced settings, but I don’t notice any difference at all between 1, 2, or even 4. I do not think this setting works on Mac?
The only way I’ve found to see significant improvement is by lowering the ‘Resolution Factor Dynamic’ to 2 using the _TestSSAOOptions command. However, these settings unfortunately do not persist between sessions.
Could someone advise me on how I can make these changes permanent, and why the ‘SkylightShadowResolutionScaleDynamic’ setting doesn’t seem to have any noticeable effect?
@Jeff maybe?
sysinfo.txt (4.5 KB)
@DavidEranen would know more about this…
But for now, I would just create a macro like:
-_TestSSAOOptions o 2 enter
And stick in the startup section under the General settings (see pic). That will at least force the setting you want until some other mechanism can be provided.
-J
Yes I can live with that, but I would prefer a more robust solution in the future. Thank you.
Hi @AMG,
Thanks for reporting this, I made a YT item: https://mcneel.myjetbrains.com/youtrack/issue/RH-83913.
The solution suggested by Jeff is a good workaround for Rhino 8.
