This has happened with most of the PDFs I have tested, so I assumed it was a common issue and posted here hoping there might already be a known workaround.
If this is not expected behavior, I can send one of the PDFs privately to support, but I cannot post it publicly because the files are confidential.
Here is SystemInfo:
Rhino 9 SR0 2026-6-16 (Rhino WIP, 9.0.26167.11545, Git hash:master @ 57b70c19c1a95d556312e40efd60cd1c4e9f7aaf)
License type: Evaluation, build 2026-06-16
License details: Cloud Zoo
Expires on: 2026-07-31
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 10.0.9
Computer platform: LAPTOP - Unplugged [38% battery remaining] ~16 minutes left
Non-hybrid graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 3080 Laptop GPU (NVidia) Memory: 8GB, Driver date: 5-19-2026 (M-D-Y). DirectX(11)
> Integrated accelerated graphics device with 1 adapter port(s)
- Windows Main Display is laptop's integrated screen or built-in port
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 12-23-2021 (M-D-Y).
- Secondary monitor is laptop's integrated screen or built-in port
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY SkylakeX MAX_THREADS=64.
C:\Users\StefanoMenci\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\BlockEditNew\2.1.5\blockeditnew.rhp "BlockEditNew" 2.0.0.0
C:\Users\StefanoMenci\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\IntelliClad\0.0.5-beta\IntelliClad.rhp "IntelliClad" 0.0.0.0
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp "Commands" 9.0.26167.11545
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp "WebBrowser"
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp "RhinoScript"
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp "IdleProcessor"
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp "UpdatesAndStatistics" 9.0.26167.11545
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 9.0.26167.11545
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 9.0.26167.11545
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp "MeshCommands" 9.0.26167.11545
C:\Program Files\Rhino 9 WIP\Plug-ins\Import_PDF.rhp "PDFReader"
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp "RhinoCycles" 9.0.26167.11545
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp "RhinoCodePlugin" 9.0.26167.11545
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp "SectionTools"
C:\Program Files\Rhino 9 WIP\Plug-ins\export_ACAD.rhp "AutoCAD file export : export_ACAD"
C:\Program Files\Rhino 9 WIP\Plug-ins\export_PDF.rhp "PDF Export" 9.0.26167.11545
Hi @Stefano_Menci,
We identified that the PDF was produced by iTextpdf 5/27/2025.
Is this correct? Were you writing the PDF from the ThinkDesign product?
Also we logged a private YT: RH-96438/PDF-Import-Issue
Since AutoCAD is failing too, it may be a defect in the way the PDF was written.
We have asked our developers to look at the issue.
You will be notified here if/when there is a fix to test.
Thanks for letting us know about the issue.
Sincerely,
Mary Ann Fugier
McNeel Technical Support and Training
Seattle, WA
