Trying to internalize spiral data into grasshopper - Gallery / Jewelry - McNeel Forum
Wish I could be of more help, I have one grasshopper class left bit preoccupied. Also had another questing link is above, maybe preoccupy some of your time, an put this on hold. In the mean-time ill link the class to the forum, we have a great teacher an some noteworthy mathematicians, I’m sure would like to comment. As listed in the link above to reparametrize this spiral bezel from rhino to grasshopper for bead work. Start by; if you will
meshing the ploy surface to minimal faces
then mesh to nurbs.
maybe extract wire frame
Input curves into grasshopper
Even as I did before by manage multiple curves an selecting each major UV.
The perhaps pipe in grasshopper to 1.35 to 2mm, enough room to set a diamond.
Utilize points for bead work
bit lost how i would channel set maybe by offsetting major uvs an internalizing data
networking surfaces to an alter degree
Thanks a lot for the advice brother man Japhy
