I have been using a definition to project a large set of objects onto an uneven surface stumbling into a not satisfying end result. I am attaching a preview:
the fourth item is the bottom side of the bounding box I created to find the center point to project. In another definition I also tried to use the vertices of the same side, rather than just the central one. Hoping that that would have helped to better distribute the geometry on the uneven surface. It did not work.
