Is there any way to convert poly surface into single surface or mesh into single surface. I have complex organic geometry which was modeled using Cinema 4d and Maya. I need single surface input for GH script to create lattice structure.
Yes and no. Technically yes and people might tell you its possible, but don’t do this. It is bad, actually very bad practise to do these conversions. You’ll need to apply the lattice to your mesh or you remodel your shape using surfaces. Merging surfaces works by using the _MergeSrf command. Fitting surfaces to meshdata needs additional propertary tools. But you should rather modify your gh script…
