For those of us who are beginners can someone explain what is a “single polygon plane”? How does one create one?
Thank you.
Thank you.
type meshplane, or if you are not looking for a plane but actually just a polygon it is called 3DFace, something which i also did not find at first. the naming is a bit strange, maybe at least mesh face, why would one call it 3dFace ok whatever hope that solves the confusion.
Interesting. @encephalon --that was helpful. But that is mesh. Does the word “polygon” imply mesh and not nurbs? Do nurbs objects have polygons?
Could one create a nurbs surface with one point in each corner and none anywhere in between?
polygons can be of course closed polylines, meshes and nurbs.
the nurbs equivalent for a nurbs surface would be SrfPt, also a bit strangely named but i hope that solves now all and further upcoming confusions
With 3 or 4 points yes. (Surface>From corner points) More corner points than 4 and the surface has to be a trimmed planar surface (made from a polyline trimming a rectangular planar surface). NURBS surfaces always have a “rectangular” structure (U/V).
