Sine wave on a curve, amplitude doesn't work
hello guys, Im trying to use graph mapper to amplify the points along the tangent
And the graph mapper is a sine curve
And that doesnt work
Could you clarify where exactly the problem arised?
I have attached the GH scripts, no internalized geometry all are parametric
Thank you!
elliptical flower installation gh.gh (30.2 KB)
You may give it a try with Dispatch and Weave, and fyi.
elliptical flower installation gh.gh (19.3 KB)
Hello Guys, Im trying to create curve on the perpendicular axis and the graph mapper doesn’t produce a sine curve,
as when I try to amplify it’s position with move on that perpendicular direction
Please help me achieve the desired curve as indicated, any component tips alone are enough
No need to download and manually edit them
You can achieve it with Offset Curve, and fyi
About Offset Curve Grasshopper Online Document
Offset+Weave.gh (8.2 KB)
Thank you for your response Jessesn, I’m in search of ways to utilize the graph mapper to direct the sine curve,
any help on having the graph mapper be helpful in the amplification of the dispatched points?
Can you please let me know if any,
Why Graph mapper-If I go with graph mapper, there are many other graphs which are there to give even more curve variations.
This is really basic, but you certainly miss how graph mapper is working. Yes it is a sinus but just half a period.
Use the little circle to augment the number of periods.
elliptical flower installation gh.gh (25.4 KB)
