Simplifyedge?
Is there a way to simplify edges after merging faces? More specifically, I’m trying to “reset” osnap points as I rely on midpoints a lot for mirroring.
You could try _MergeAllEdges…
Hi Mitch - The problem is that does not merge them fully… this has come up before -
https://mcneel.myjetbrains.com/youtrack/issue/RH-46908
@stn - for now the answer is no, I’m afraid.
Yikes, guess I should start a habit of exploding and rebuilding…
thanks for the quick response!
maybe after exploding you can use _RemoveEdge instead of Rebuild.
