Who can explain this behavior of the Simply Tree component. It works as expected when I have 2 or more branches and flattens each branch to {0} structure. But when I have one branch it ingores it, and the original branch is maintained.
I can fix it with ‘Surify’ node, but still want to understand why
I also faced the same issue and used stream filter based on the branch count. Though it’s just a workaround I implemented for a time being, I think it will become highly cumbersome to use the same stream filter all over the places in a large complex code.
Found out surify in my gh and wondering if it’s a native component?
it is, and it’s one of those components you never know it exists when you need it most. I prefer to use it over simplify. Although a good habit it to make use of the data structure and don’t make use of simplify / flatten just for 'data tree aesthetics ’
