btw when I use move-edge, and then want to fillet the edges I get an error because actually the face is still there.
I though using join edges but this doesn’t work, anything else I could do?
In this case may be you should remove faces before move the edge explode/remove/move/join/cap and done., or use others solutions, but you will have more manipulations.
