Simplify a specific branch
there is a solution to simplify as a picture attached?
Thank you
Split the tree, than shift the path and merge it back.
Simplify it upstream before it was merged.
I agree with @Joseph_Oster
make sure that you don t create this kind of mixed
paths in your data tree.
handle the problem where it got created.
to answer your question:
you can use path-Mapper with multiple mapping statements - with some limitations:
(if indices occur more then once {0;1} and {0;1;0} ) you might not get the expected result.
attached example shows this limitation
(and provides a dataset for others to play with)
PathMapper_2statements_00.gh (9.5 KB)
