Simple UV mapping bug
Hi Mcneel
Create a circle, extrude it, unwrap it - works fine. Now chamfer the edges and unwrap it so that the top face and the top chamfer is one island, the side is one island and the bottom and bottom chamfer is one island. Now the side surface is reduced to a point in the UV editor - see video.
-Jakob
System Info
Rhino 8 SR12 2024-9-24 (Rhino 8, 8.12.24268.13001, Git hash:master @ 01a91d2d13b556683de4cecbd523f46a8bcfab52)
License type: Commercial, build 2024-09-24
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 95GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 7-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.86
- Windows Main Display attached to adapter port 0
- Secondary monitor attached to adapter port 1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-23-2024
Driver Version: 31.0.15.5286
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.12.24268.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.12.24268.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.12.24268.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.12.24268.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.12.24268.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.12.24268.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.12.24268.13001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
C:\Users\jn\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
Thanks @Normand , filed as https://mcneel.myjetbrains.com/youtrack/issue/RH-83987
Looks like the As Rigid As Possible unwrap method will work here in the meantime.
Hi @BrianJ
D’oh! I’ve grown so accustomed to conformal working most of the time, that I completely forgot about that one! But I guess conformal should still yield a more sensible result :slight_smile: Thanks Brian! :slight_smile:
-Jakob
RH-83987 is fixed in Rhino WIP
