Imagine the pile of data which is a set of groups within a groups and the it is grouped at the end resulting a read of basillion instances (without hierarchy) in a group panel, and I’m talking about hundreds.
Is it possible to script an action that removes all subgroups living the last ones? Not sure if I explained it well, if not, I will try harder.
You might try the following…
Option Explicit
Call RemoveNestedGroups()
Sub RemoveNestedGroups()
Dim arrObjs,strObj,arrObjGroups,strTG,strGroup,arrGroups
arrObjs = Rhino.GetObjects("Select objects to process")
If Not IsArray(arrObjs) Then Exit Sub
For Each strObj In arrObjs
arrObjGroups = Rhino.ObjectGroups(strObj)
If IsArray(arrObjGroups) Then
strTG = Rhino.ObjectTopGroup(strObj)
For Each strGroup In arrObjGroups
If strGroup <> strTG Then
Call Rhino.RemoveObjectFromGroup(strObj, strGroup)
End If
Next
End If
Next
arrGroups = Rhino.GroupNames()
If isArray(arrGroups) Then
For Each strGroup In arrGroups
If Rhino.IsGroupEmpty(strGroup) Then
Rhino.DeleteGroup(strGroup)
End If
Next
End If
End Sub
Note, it is difficult to know with nested groups which is the objects uppermost group. Rhinoscript has a method ObjectTopGroup() which theoretically finds this, but I’m not sure it’s 100% reliable. The method is not currently exposed in Python, hence the VB script. Try the script out on some copies of files first.
The above in an .rvb file
RemoveNestedGroups.rvb (750 Bytes)
–Mitch
Hi Mitch
You never fail to amaze me. if I only knew how to apply this alien language into my workflow…
Can it be converted to rvb? I understand that PY is not possible in this case.
Many thanks for your effort.
P
I threw it in in my post above. Note, I haven’t tested it at all, so let me know how (and if) it works…
Mitch
It works like a charm.
I did a quick test. It went from hundreds to hundred groups. I have later isolated selected groups to check if anything nested is left and the result was: none. Congratulations.
I would like to offer you a beer or two next time I see you in STF in London
Definitely !!
