I am trying to find a way to input data into the ghpython node from panels in order not to have to hard code the following information into the ghpython node:
families = {
“Williams” : {“Joe” : 44, “Ellie” : 43, “Bill” : 11},
“Rogers” : {“Michael” : 70, “Sally” : 69},
“Timson” : {“Tim” : 51, “Lisa” : 52, “Ryan” : 24}}
print(type(families))
I can’t set type to in the input on the ghpython node.
Any ideas?..
Michael Wickerson
I want to use the data with the One-liner snippet:
old = [x for x in families if any(y > age for y in families[x ].values())]
You can do this:
You should use " " or ’ ’ instead of “ ”, because the “pretty” quotes won’t be parsed by eval()
, since they are not used in Python to declare strings.
Genius, clear, cogent, concise, intelligent! Thank you! Michael Wickerson
those quotes have tricked me up before when reading AAD by Arturo Tedeschi.
Michael
Then set
globals()[foo] = bar
to set the variable name to families
One can also use the standard json
module for parsing a string to a dict:
210531_StringToDict_JSON_GHPython_00.gh (2.8 KB)
