Simple opening in surface with wirecut
i want to make a simple opening in surface with wirecut but it keeps doing this, is there any other way? i just wanna create rectangle hole in wall surface
Upload a .3dm file with the input geometry you used. Drag the file to where you type a post, or click on the vertical arrow icon above where you type a post.
Draw a rectangle on the surface and use Trim. That should work even in bootleg versions of Rhino.
