Simple Gumball question
Why does this gumball have a mind of its own? I have gumball set to align with c-plane but when I select this part it’s obviously not. When selecting other parts; it works as intended. When selecting multiple part including this one; it works as indented. Only with selecting this part by itself the gumball is crooked. I’ve moved this assembly to a blank rhino so all setting are default. I’m assuming it has something to do with the part itself but not sure what to look at/ change.
Looks like you might have relocated the gunball for that object. Just select object and in the gumball options select reset gumball. That should bring you back to where you need to be.
