Simple grid problem
HI
could someone tell me how to convert “p” plane input in surface input for the grid comand ?
You can’t. Grids are only made on infinite planes. You can however morph your grid onto a surface after you make it on the plane. The question then becomes how you want to morph it. Do you want to keep the grid edges straight and only move the points onto the surface? Or should the edges also be curved along the surface?
if is possible it would be great to learn both procedures this is just an exercise for me !
thanks
I’d like to adapt micro-drilling patterns to any surface
3fe46c85197c8d48dfbe493b1d33a13a
