Simple Closest Points Grid
Hi all,
I have several grids of circles from which I extract the center points (around 8500 in total), but I am unable to find a simple solution to use these ecenter points to create a grid (points connecting with a maximum distance of 3.1 units).
Attached is an example of what I’m trying to do (done manually) and the GH & Rhino file.
Appreciate the help, thank you,
F
grids.3dm (8.2 MB)
grid.gh (176.3 KB)
This is a strange problem… I finally resorted to SrfSplit, which as you can see, is very slow (1.3 mins.). But it works, eh?
grid_2022Feb1a.gh (194.0 KB)
If you just want lines, use Proximity 3D with the good max distance.
grid_LD.gh (179.7 KB)
Interesting but different in two ways:
  1. Mine are grouped such that each branch is a collection of nearby grids.
  2. Yours covers the hole where there is no grid, mine doesn’t.
Mine:
Yours:
When I replace SrfSplit and use Boundary as you did, I get the same result:
grid_2022Feb1b.gh (187.7 KB)
@Joseph_Oster , apologies for the late reply, I’ve been using your solution all and it was exactly what I was trying to solve. I will post the result to show what you have helped me solve once I’m done. Much appreciated for your help once again! :grinning:
@laurent_delrieu Thanks for the effort, yours also works! :grinning:
I have yet to understand the implications of the difference between solutions as I have required it for simple step-by-step tasks, but thank you both.
@Joseph_Oster Here’s where you helped me save a day of work, thank you Joseph! :pray:
