I’m trying to draw an arc using the native arc component with an angle domain of 6.02 to 0.03 radians
It draws the big arc from 0.03 rad all the way round to 6.02 instead. Doesn’t matter if the domain is 6.02 to 0.03 or 0.03 to 6.02
Is there a way to draw the short arc that crosses the x-axis?
ARC_QUESTION.gh (4.8 KB)
I think you need to rotate the input plane
ARC_rotate-plane.gh (16.6 KB)
What if I’m trying to do this…
ARC_QUESTION.gh (7.8 KB)
That first arc doesn’t work because it draws the long one not the short one
Yes. By using a negative starting domain, or exceeding 2 * Pi:
ARC_QUESTION VR 1.gh (29.6 KB)
6.02 to 0.03 and 0.03 to 6.02 define the same larger angle arc but in different directions.
Oh circle, how do I dash thee?
let me count the ways…
ARC_QUESTION VR 2.gh (19.2 KB)
I can think of more. Some are sillier than others.
Thanks for all the replies. When I’m back at the desktop I’ll explain what I was trying to do.
All this really helps though.
I was trying to do this…
Used the curve shatter in the end so @Volker_Rakow can get the Solution but thanks to @martinsiegrist too!
I’m sure there’s prettier ways of doing what I was trying to do. I’m a bit out of practice with GH.
